S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
380 sec questions
Old Jul 23, 2013 | 06:08 AM
Jordo2's Avatar
380 sec
380 sec questions
Gday, im new to the forum, and to mercedes cars. Today i got hold of a really crap 1984 380sec. Its got very hi km(411,000). It runs and drives reasonably well, but has been treated like garbage in every way for some time, and has the following list of problems...so far.
What seems to be a bad leak on the passenger side exhaust manifold or gasket..(rhd car)
...or it may b a lifter? Im unsure but its noisy... Noise noticably lessens briefly on decelleration.
Severe leak of self levelling fluid...appears to leak under car near the resivoir.
No aparent 4th gear engagement? (all other gears work..no slipping noticed).
Trans lever looks to be a bit out of place when in drive position.
Drivers window not secure in track
Runs a little hot..90-95 c
A/c inoperative
Oil press is at max when cold...and just under 2 at idle when fully warm, and at 3 (max) when driving. Is this ok?
Id appreciate any and all opinions on diagnosis/repair for the above issues.
Thanks in advance.
Old Jul 24, 2013 | 10:39 AM
BENZITCH's Avatar
1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
1)Oil pressure is fine readings
2)Self leveling leak could be from the ram connection via a hydraulic line going
to the accumulators
3)Car starts in second, not first, so you would only notice 3 shift points. 1st gear is gotten by moving the shifter into the lowest position, clicking to the left, and put back in drive, and than take off.
A/c inoperative
Thanks in advance.
Old Jul 24, 2013 | 10:44 AM
Jordo2's Avatar
380 sec
to the accumulators
Thankyou very much.
