S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Is It Time To Replace Your Distributor? Parts Ready To Ship! By Pelican Parts
Old Aug 12, 2013 | 03:06 PM
PelicanParts.com's Avatar
SPONSOR
The distributor on the W126, like any distributor on any car, plays an important role in the smooth and efficient running of the engine, and while the distributor itself should last the life of the car, there are several components on or in it that wear out, need servicing or replacement over time. The first of these is the distributor cap. The W126 distributor cap has a cover built into it and is removed as one piece. To remove the cap, remove the two bolts holding the distributor cap to the distributor. Use a large flat head screwdriver, push the screw down and give it a half turn, it will pop up when released. You can now remove the cap and wires as one piece. Check the cap for dark and charred scorching on the inside as this can mean “arcing,” meaning there may be a problem with the distributor.
You can check the rotor as well. It’s always a good idea to replace cap & rotor together.
We carry brands Genuine Mercedes-Benz, Bosch & Beru ignition parts for your W126 Mercedes. Click here, then enter your vehicle’s year to start shopping.
There are several very important notes and steps to take when performing this project. Learn more here: Replacing Your Mercedes-Benz Distributor
Let us know what questions you have!
