S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Intermittent Electrical Issues? It May Be Your Ground Strap! By Pelican Parts
Old Sep 4, 2013 | 02:29 PM
PelicanParts.com's Avatar
SPONSOR
If you are having any sort of electrical problem, from a battery not charging to intermittent switches or lights, one of the first things you should do is check your engines ground. The engine is isolated from the frame of the car by the mounts and needs a good ground for the electrical system to function properly. The ground strap provides this, but it is exposed to the elements and does corrode and or become lose over time.
Always check or replace your ground strap first, before replacing any electrical component on the car.
With less than 30 minutes and a 10mm wrench, you can replace your ground strap wire and leave those electrical issues behind!
For further product information, click here
Follow our clear install instructions:
Replacing Your Engine Ground Strap
Old Nov 7, 2013 | 09:20 AM
Firewater's Avatar
1988 560 SEL, 1985 500 SEC Euro AMG
Where can you get new ones? I can't seem to find the part number for them in EPC.
Old Nov 8, 2013 | 04:28 PM
SPONSOR
Which car Firewater?
