S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Warm up regulator
Old Jan 20, 2014 | 04:41 AM
sergio.lasagni's Avatar
W126 380se
Warm up regulator
Hello,
I have a 1984 w126 380se (Euro). When I start the car in the morning, it idles very low (almost like it wants to die), once the engine gets warm, everything is fine.
I have replaced the idle control unit, idle control valve working 100%. Once the motor if warm, it revs between 600 and 700 which I believe is fine.
I tried testing the cold start valve but get no power through to the electrical point on the valve. Not sure if it get's power on start up or if it's waiting for a sensor to send through power.
How can I tell if the warm up regulator is gone or just a sensor which is not working correctly, if it is a sensor, where should I be looking?
Any assistance is greatly appreciated.
Sergio
Old Jan 24, 2014 | 12:44 AM
W126 380se
Problem sorted. Found out the warm up regulator was faulty, bought one from a scrap yard, fitted it last night and runs like a dream now.
Old May 1, 2014 | 03:12 PM
Nick Danger's Avatar
1984 380SE
I am a new owner of the same car, an '84 380SE. I have a similar problem, the vehicle starts easily and idles fine but sputters and hesitates when I step on the gas pedal, like it's starved for fuel. Everything is fine once the engine has warmed up for a few minutes. Does this sound like the warm-up regulator?
Old Sep 10, 2014 | 12:24 PM
eutechcondor's Avatar
380 SeL
Smile warm up regulator
Hi fellows as a newbe : where is the warm regulator rpm idling at 1500 ??
