S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Warning Lights!!!!
Old Nov 20, 2003 | 08:23 PM
izzodesh's Avatar
ML 55 and 420 SEL
Warning Lights!!!!
ok here's the deal..
i am driving at about 75mph and just chillin and all of a sudden ALL the warning lights turn on from left to right......from parking brake ...battery low...oil...lights...asr...abs....washer fluid...EVERYTHING! even some on the dash like the snow tire one...
I pulled over and everything seemed fine and the engine ran perfectly fine...but...
when i got home i check under the hood again with a light and saw a few frayed wires coming from a black cylinder type thing... i will take pics and post soon...but does anyone have an idea?!? i really need help guys! thanks in advance i hope ppl like supersec can help cuz out in PA we dont have dealerships...i would have to use a gas station repair type thing..
sorry for the length just realllllly freaking out!
Old Nov 21, 2003 | 12:07 AM
86560sel's Avatar
1988 Mercedes 300SEL, 1991 Lexus LS400, 1972 Chevrolet Kingswood Estate, 1973 Pontiac Grand Ville
My old 1981 Toyota Cressida would do this. We liked to have never found the problem. Finally took to the Toyota dealership. They traced it down to a bad relay in the fuse box that controls the lights. Mercedes probably has different things controlling the warning lights, but this was the problem on my old car. Good luck.
Old Nov 21, 2003 | 01:50 AM
Jer's Avatar
Jer
1994 E320
Did the gauges fail when this happened?
A few years ago I had a similar problem. The gauges failed (except the speedo as it's cable-operated) because the fuse contacts were corroded. However I don't remember the warning lamps coming on.
Whatever you do please don't take your Benz to a gas station! They'll hack it up!!!! There has to be a dealership or indie MB shop somewhere!
Old Dec 1, 2003 | 04:37 PM
izzodesh's Avatar
ML 55 and 420 SEL
i wouldnt take it to a gas station for anything major but all they needed to do was install an alternator belt...
8) thanks for all the help thou !
