S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
85 SEC 126.044 AC Wiring Diagram Help
Old May 17, 2014 | 11:12 AM
nsmith17044's Avatar
1990 560SEL
I have taken my 85 SEC out of storage and found the AC compressor wouldn't cycle. System pressure was good so I checked the sensors and found the low temp sensor was open. No surprise after such a brutal winter and I believe it may be original. So to prove out I shorted across to see if the compress would cycle on. No go! I then found I didn't have 12V at any of the sensor terminals. Fuses are good. I tried ringing out the lines in ACC83-85.pdf page '306' and started finding some wire color / function discrepancies. I do have 12V at the interior control head pin 12 on C2 and output at pin 6 on C1. Button changes on the control open and make the connection as expected. Therefore I was expecting 12V out at the sensors. Compressor coil is good and activates when I 'hot wire' it for testing.
There is a black/red and black/red with a green dot at the sensors. Neither of these have 12V as I expected (disconnected from sensor). There is a brown and a brown/blue wire for the other sensor. The brown wire is ground but I cant' see / find where the brown/blue wire goes. These colors are different than the diagram. Since the brown wire for the one sensor is ground, I assume this is a current path for a relay. However I can't find this path and I don't see a wiring diagram that is similar.
So, is there a 'correct' wiring diagram that applies to this car? Anybody seen this before? I'm not sure how to continue troubleshooting since I don't have confidence of the wiring diagram. Any tips / hints would be appreciated.
Nathan
Old May 19, 2014 | 04:05 AM
Tony Funches's Avatar
1988 560SEL
European, USA or CHINA manufacture origin of the car? Makes a Diff ...
Old May 20, 2014 | 05:38 AM
1990 560SEL
The car is USA as best of my knowledge. I do believe I figured it out. I was confused as to the temp switch for the fan control and confused this with the evap. core temp switch (which was open). I shorted across the evap temp switch and did get compressor activation. However I realized now I also now have a condenser fan issue.
