S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Accelerator pedal flop
Old May 27, 2014 | 10:29 PM
edwardb1ster's Avatar
1991 Mercedes Benz 300SE
Hi All,
I have a 1991 300SE with a few problems-- but none as irritating as my accelerator pedal that is just sitting on top of the throttle actuator and falls out of place. I have replaced it once, noticing that there was nothing that connected the pedal to the throttle mechanism. I just let it lean against the actuator link and hoped for the best. It has now worn down due to use, and I can't believe I would have to buy a new pedal every few years.
Second item, my blower motor for the climate control does not work any longer, and I'm hoping the fix is as simple as replacing a fuse. I apologize for the length of this post-- thanks in advance for your suggestions!
Ed
Old May 28, 2014 | 12:28 PM
oldsinner111's Avatar
s320
Buy a OEM pedal I've replaced mine 3 times,this time I'll get OEM
Old Jun 24, 2014 | 09:16 PM
hey_allen's Avatar
'82 300SD, '84 500SEC
The throttle paddle is cheap from the dealer, ~$15 if I remember correctly.
As to the blower motor, you might find a fuse in the fuse box, or possibly a strip fuse in a separate little box on the wheel well ahead of the fuse box. There was a retrofit for w126 chassis cars that removed the blower motor circuit from the main fuse box due to high current draw, and put it on the 30 amp fuse outside.
Old Jun 25, 2014 | 10:59 AM
ECSTuning's Avatar
Former Vendor of MBWorld
2012 SLS AMG
We have the Throttle Pedal available on our site. We offer both genuine Mercedes-Benz as well as aftermarket options. You can get to the Throttle Pedal by clicking HERE, or by clicking on the photos below.
If there are any questions I can answer about this, please feel free to post or send a PM!
