S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
126 AC problem
Old Aug 30, 2014 | 06:14 PM
juliowong's Avatar
420 SEL
Red face 126 AC problem
So it was spinning and blowing air yesterday.. But today it stopped.. I checked the blower fuse and the kilma.. They looked ok.. What do you guys think.
Before posting , I searched the forum.. And couldn't find anything close to my problem.
I took out the climate control
Unit out today.. Cleaned it and inspected the plugs . Put the whole thing back and still no sign of life...
Thanks guys
Old Aug 31, 2014 | 03:24 PM
Rodolphe10's Avatar
S420 1995
Have you check the blower motor under the dashboard on the passenger side? If you hook up a battery to the pos and neg prongs of the blower motor, it should spin. If it doesn't then you will have to replace it. This is what it looks like: http://www.myrecycledparts.com/product_p/12824.htm
Rodolphe
Old Aug 31, 2014 | 11:21 PM
juliowong's Avatar
420 SEL
Smile
will try that tomorrow. thanks
now I am going to look up How to locate Blower motor.
thanks rodolf!!
Old Sep 1, 2014 | 09:33 AM
Rodolphe10's Avatar
S420 1995
Easy, it is under the glove box compartment. You have to remove the carpet piece that are in front of you knees when you are seating. Once you remove this part, you will find a cover that looks like this: http://www.myrecycledparts.com/product_p/12825.htm
Remove it and you will see the blower motor.
Let me know if you need more help.
Rodolphe
Old Sep 1, 2014 | 01:30 PM
juliowong's Avatar
420 SEL
Took the blower out and connected to the battery.. It spins like a champ so how do I check the regulator.. Or could it be something up the line.. The climate control? Thanks for your help man
Old Sep 1, 2014 | 01:36 PM
juliowong's Avatar
420 SEL
Here is! Not to difficult but my back hurts a little
Old Sep 1, 2014 | 02:15 PM
Rodolphe10's Avatar
S420 1995
There is no easy way to test the blower regulator. It is usually a part that will go bad this is what it looks like and it is next to the blower motor.
http://www.myrecycledparts.com/Produ...ductCode=12826
Also, the ac control unit may have gone bad. What year and model is your car?
