S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Peddle stick
Old Feb 2, 2004 | 08:47 AM
Blackbob's Avatar
91' FireBird
Peddle stick
My moms gas peddle in here 300SEL sticks soemtimes and will continue to climb when you get off teh gas. Anyone know the remidy for this problem ?
~BB~
Old Feb 2, 2004 | 01:00 PM
Jer's Avatar
Jer
1994 E320
The accelerator cable coule be stuck. Grease the linkages at the accelerator pedal and the throttle body (on the engine).
Old Feb 3, 2004 | 06:02 PM
Blackbob's Avatar
91' FireBird
I'll try that and let you know what happens.....
~BB~
Old Feb 8, 2004 | 02:51 AM
schwarzwagen's Avatar
300SEL
there isn't a cable in the system, only the elbow links. Take the air cleaner out, then you will see the linkage. Have someone actuate the gas pedal for you as you lub the system.
