1986 300SDL Diesel Injection Pump timing
I am just trying to verify that the checking / setting of the Diesel injection pump timing on this OM603 6 cylinder , is accomplished by aligning the Slot by using the Special spring loaded tool that screws into the side of the pump ??
Thank you
Thank you
Thank you , Vin # WDBCB25D9GA274900
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
