w126 560 engine with w140 500 gearbox
can i install a w140 500 gearbox on a w126 560 engine with no problems?
what would be the conversion process, will i keep the 560 differential?
i doubt the 722.6xx would bolt up,you need the trans computer,the old 4 speed w140 trans would not do justice. The w140 motor is better,I'd swap both and electronics,and disable asr.
