300SD Wont crank!
2006 CLS55AMG, 1997 S500C, 1992 300CE Sportline, 1984 300SD
300SD Wont crank!
Hello guys,
i dropped off my 300sd to the alignment shop, battery died and i believe it was jumped incorrectly. now the he battery light on the cluster stays on and wont do anything else even if i try to crank it or turn the ignition. Battery light will not turn off unless i disconnect the battery. I tried replacing the voltage regulator and the ignition switch with no luck! Any help would be appricated!
