At what RPM UPshift in 84 300sd?
84 300sd (w126) diesel
re 84 300sd (w126, 4-spd automatic transmission)
On level ground, at what RPM should the 4-spd auto trans UPshift through the gears?
depends on how much throttle is pressed,normal drive 2000,or 2500.High speed 4200. There's a cable that runs from transmission to throttle linkage passanger side.Adjust like bicycle brakes
Hi,
i have a manual of the 300sdl ... maybe the "shift points" are compatible with the 300sd ??
take a look .. it´s for the model 126.125 .. it shows the km/h or mph...
Kind regards
Lars
Kind regards
Lars
