S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Front lower control arm bushings W126
Old Apr 20, 2018 | 02:10 PM
richnronda's Avatar
1986 300SDL , 1987 300TD
Trying to find an installation tool for Front lower control arm bushings. KTC Tools has some nice tools and actually lists a tool, but it is Out of Stock . I also have read that this tool MBZ2006 may NOT be for the Front arm but rather the front bushing of the REAR arm ?? Any help greatly appreciated. Thanks
Old Apr 22, 2018 | 07:50 AM
oldsinner111's Avatar
s320
i rented one free at advance
Old Apr 22, 2018 | 12:43 PM
richnronda's Avatar
Thanks for quick response. Did you apply that tool to a W126 ?? Looks like you may have a different model...S320 ? According to the info. I have come across , the tools vary ever so slightly from each specific model.
Old Dec 30, 2018 | 06:00 PM
dsm1's Avatar
02 ML55, 02 E320, 98 SLK230, 85 300SD, 84 300SD, 914GT/V8
I've used threaded rod, washers and a socket to install w126 control arm bushings. I've rebuilt many front ends using this method.
Old Dec 30, 2018 | 09:03 PM
richnronda's Avatar
Thank you!
Old Nov 13, 2019 | 08:36 AM
impalaman1's Avatar
W126 300SD
Could you provide a little more detail on your process? The second end cap seems to be the hardest part. Do you press on the center part and outside ring
simultaneously ? What size socket?
Having an issue with second end cap ballooning when trying to install.
