89" 420SEL Rear Window Regulator Slider "Jaw" How to Attach?
Have done many window regulator repairs over the years. Now on a 1989 420SEL (W126) I ordered a NEW Mercedes-Benz Window Regulator Guide Jaw - URO Parts 1267200042
This clip comes up with many Google searches.
Question is, I see the OLD OEM rectangle slider and see clearly it is held via a rivet PIN. But can't figure how this version till attach to the regulator arm.. Thoughts anyone ? It is a tight plastic multi part piece that appears not to require disassembly but scratching my head
https://www.eeuroparts.com/Parts/137...aw-1267200042/
https://www.autohausaz.com/pn/119656...RoCKOcQAvD_BwE
ndccpf1 (07-15-2018)
I found out that piece is also used on the window regulator but the one I needed is the slightly rectangular one chat slides left-to-right on the window base channel. I used the piece and modified it as part of it is the same size as the slider that always breaks (the left to right slider).
Window now working again...
