S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Power window switch wiring problem
Old Feb 26, 2019 | 07:23 PM
Zamo's Avatar
1982 300sd
when replacing the left rear window regulator on my 1982 300SD, the wiring harness holder that attaches to the switch completely fell apart leaving me with 6 loose wires. I compared the wiring to the right rear window switch and got them in place for the most part. There seems to be a crossed wire somewhere as the window switch works correctly but the console switch works the window backwards. Up on the console switch makes the widow go down and down makes it go up. Can someone share a wiring diagram or take a picture of the wiring on the rear left window switch? Thanks.
