S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
HOW TO PHASE AN MB 2 PIECE DRIVE SHAFT??
Old Aug 21, 2019 | 02:28 AM
Steve Hitch's Avatar
83 300SD
I am having the cracked flex plate replaced on my 83 300SD. The drive shaft needed a new carrier bearing so decided to do it myself, Problem is, the shaft was handed to me in two pieces and nobody had marked it for proper alignment, I can phase a drive shaft w/multiple u-joints, but w/this MB setup, I'm lost. If anyone can tell me how it is done, I would certainly appreciate it.
Thanks, Steve
Old Dec 2, 2019 | 12:33 PM
jbeech's Avatar
72 R107, 04 W463, 05 W211
Steve,
I don't think you have to phase the shaft because the drive shaft uses flex joints at each end. Anyway, I am seeking the same information because I purchased a used driveshaft for purpose of replacing the u-joint and then replacing the entire drive shaft which is in my car. However, what has me thinking about this is I replaced the flex disks and center carrier bearing recently (and was careful to mark how the two shafts came apart in order to maintain alignment) but now I have a vibration under acceleration, which I don't recall having before. Note, I replaced the flex disks and carrier bearing because my car is eating engine mounts about every six months. Anyway, I felt a flat spot in the u-joint when I had it apart and because the u-joint in mine is staked (meaning you can not just remove the circlips and replace the u-joint and MB want to sell you an entire $1000 drive shaft), I sourced a used shaft (which the seller disassembled into two pieces before packing). This, as I mentioned above, is for the purpose of cutting off the yokes and welding new ones on (so i can replace the u-joint if the need arises again in my lifetime). Maybe we should compare notes. Reach out to me at 407-302-3361
