S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
E / S switch automatic transmission defective
Old Jul 23, 2020 | 05:20 PM
W126-420SE's Avatar
W126-420SE
Question E / S switch automatic transmission defective
Hello, since I have my car I have noticed that the selector that is next to the gear lever and that allows you to switch between the different economy and standard modes does not work. The car is stuck in economy mode so it doesn't usually slow down when I accelerate further and always shifts to no more than 3000 laps and the only way to get a little more lively is by using the kickdown. Can someone tell me what the problem may be, so the car always goes in economy mode and does not change to standard? On the other hand I would like to know where I can locate the valve that regulates the selection of both modes in case this is the fault. Thank you very much.
