S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
500 sec with no air trough center vent
Old Aug 16, 2004 | 08:17 PM
hansa320's Avatar
2005 cdi 99k/11 E350BLUETEC 97K/92-400E/85-500sec
Greetings again from FL.
My 85 500 sec has now developed a new problem. With air on, the center vents does not supply any airflow to the cabin at all.
Any thought are greatly appreciated.
Stein
85 500 sec euro 225K
Old Aug 18, 2004 | 05:39 PM
Jer's Avatar
Jer
1994 E320
When you say "with the air on" are you referring to AC? If so, you have a problem; the center vents only function when the compressor is running. The vacuum actuator could be leaking. I think you can access it by removing the glove box.
Old Aug 18, 2004 | 08:37 PM
hansa320's Avatar
Thanks for the reply. Yes I am talking about the ac. Cold air on the side vents and in the rear, but only a small amount (bearly noticable) in the center.
I pulled the glove box, and the only vacum actuator accessable there where for the defrost (up-window) and the manual for the passenger side vent. I tried to pull the under dash on the driver side, and did not see any actuators.
Guess I could pull the speedo cluster to see what is behind it.
I am about to sell the whole D** car...
The lack of center air is close to unberable in FtLauderdaler. I am cruising ebay for a cheap replacement. Must have cold air.
Thanks again
stein
Old Aug 20, 2004 | 11:19 PM
darky_minded's Avatar
cl600
hello hi there i want to ask u somthing u said that the air flow is week from the front vent ok tell me is there any air comeing out from the top vent the one under the windsheeld coz if there is air comeing out from it that means thers something wrong i think witha valv and u need to change it
