S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
antilock warning light coming on?
Old Oct 27, 2004 | 04:46 PM
golfboy's Avatar
89 420 SEL and 97 E320
My 89 420SEL's antilock warning light is coming on sporadically.
On my 10 mile commute to work, it may come one once or twice and stay on anywhere from a block, to 2 miles, then it goes off by itself.
When the light comes on, the RPM's go up about a 1,000.
This has been going on for about two weeks.
Anyone have an idea what is causing this, and why RPM's would be effected if the antilock system was faulty?
I'm wondering of maybe an O2 sensor is malfunctioning, but again, why would the antilock idiot light come on for that?
Old Oct 27, 2004 | 08:32 PM
dtkw's Avatar
1986 560SEL, 97 BMW 740iL
That could mean your unit is going bad. I have replaced mine with a rebuilt unit. But it could be some bad wiring or fuses.
Old Oct 27, 2004 | 10:22 PM
w123_w126's Avatar
85 500 SEL
The OVP relay may also be malfunctioning or needs to be replaced.
Old Oct 28, 2004 | 02:40 PM
egxpimp's Avatar
F248 F1
my abs light came on when my car was trying to tell me my master cylinder was dying-then it died then i knew why the light was on- i replaced it and it went away.....maybe yours is diff
Old Oct 28, 2004 | 09:12 PM
golfboy's Avatar
What's OVP?
Old Oct 28, 2004 | 09:14 PM
golfboy's Avatar
hmmm. Why would my RPMs go up if it's my Anti-Lock or a master cylinder?
Old Oct 29, 2004 | 02:25 AM
egxpimp's Avatar
F248 F1
i dont know its a weird car, maybe ur having shortage somewhere? hmm when u accelerate does it throw black smok ? then it might be your frequency valve...orr hmmm im not sure to behonest with u.
Old Oct 29, 2004 | 10:41 AM
Jer's Avatar
Jer
1994 E320
OVP is the Over-Voltage Protection relay. It cuts off power to sensitive electronic systems, like ABS, if the voltage gets too high. Sometimes the fuses in them blow, or the whole relay fails. This might also explain the high RPM, because the engine management goes out, too.
Old Oct 29, 2004 | 05:42 PM
golfboy's Avatar
Thanks, I'll look into that... best explaination yet!
