Set fire to my 420SEL
Disconnecting alternator output the short disappears and I'm able to crank the vehicle but there is no start. Replaced OVP fuse and inspected the rest, fuel is good but I'm not getting spark. CPS tests good (900Ω) but I'm getting no voltage across the coil primary inputs. (well actually it goes from zero to 0.4mV upon crank).
Can anyone provide relay and wiring diagrams so I can fault find a bit better?
thank you.
