S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Acceleration problem with the 420 SEL...
Old Nov 5, 2004 | 11:45 PM
MikeWash's Avatar
In the last two weeks there has been a problem with accelrating above 50mph. Today I had a hard time starting the vehicle. After starting, the car wanted to die after acceleration at any speed. Any ideas as to what might be wrong ?
Old Nov 5, 2004 | 11:57 PM
MikeWash's Avatar
Almost forgot...
It's an '87 420 SEL.
Old Nov 6, 2004 | 04:22 AM
dtkw's Avatar
1986 560SEL, 97 BMW 740iL
Fuel filter dirty? Fuel line? Injector issue? spark plugs? check them if I were you.
Old Nov 6, 2004 | 12:58 PM
MikeWash's Avatar
Another thing
It has to sit for at least 15min after running to start up again.
Old Nov 7, 2004 | 11:15 AM
m117968's Avatar
96 S600 Euro, 91 560 SEC, 88 300TE, 87 560SEL, 86 560SL, 80 280SE, 64 Austin Healey 3000MIII
Sounds as though you are having a major fuel delivery issue. I would start w/ the fuel filter. If possible, take your car to a shop that can check your fuel pressure at the fuel distributor. I had a 420 in my shop w/ a similar problem (although not as bad..) and it turned out to be two fold, a bad fuel pressure accumulator and a tired fuel distributor.
How many miles on your 420?
Jonathan
Old Nov 10, 2004 | 11:29 PM
lars's Avatar
05 CLK 500 cab
Fuel pump relay?
Old Nov 12, 2004 | 06:24 PM
m117968's Avatar
the FPR generally is a hit or miss deal..either it works or it doesn't..
Jonathan
