S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Engine air starving when getting warm?
Old Feb 16, 2024 | 02:14 PM
thomas311's Avatar
1987 560SEL, 1988 560SEL, 2016 S600 Maybach, 2018 AMG GTC
Hi everyone, its been a while since I posted. But I have been doing a lot of reading about my recent MB projects I started in December 2023.
I recently acquired two 560SEL (1987 and 1988). Both in decent condition but different issues. Currently I'm working on the 1987 and I ran into an issue I could not solve so far by studying the forum or you tube.
The car fires up great and idles a bit irregular but good at around 700-800rpm. Then after a minute or two it gets rough, almost like running on only some cylinders or so until it eventually stalls.
Here is what I did so far just to give an idea of things already done (not necessary related to this issue as it wasn't there when i acquired the car).
- did the timing chain replacement incl. rails, injector seals and holders and the big vacuum lines connecting to them. Dropped oil pan to check if clean.
- replaced all belts
- did a coolant flush to replace coolant with what's considered the correct coolant.
- replaced all rubber fuel lines from tank to pump and return to tank plus accumulator as I had a warm start issue.
- then I replaced manifold gaskets as I had an exhaust leak
- then the car wont start at all (just cranking), replaced the ignition coil and it starts right away.(but still stall when getting warm)
- ohm tested the crank position sensor => reads good.
- disconnected the idle air valve to see if this makes a difference to my issue: just higher idle after startup, but will still show the issue once warm
I was considering a fuel supply issue, but pumps running fine and the following makes me believe its an air related issue:
When the car starts getting into rough idle and I gently push the air flow plate with my finger down (air filter housing of course removed) and with just a tiny little push the idle will recover to normal.
On Benzworld a similar issue was described but only with assumptions, no solution (https://www.benzworld.org/threads/56...g-why.2834985/).
What could be the potential reasons according to you guys experience? I think may be vacuum leak, but before I jump into a smoke test, maybe someone has a simpler idea about a fix or something to try?
Thank you for your comments!
Old Feb 17, 2024 | 08:17 AM
thomas311's Avatar
Update: I got a reply on BenzWorld and the issue was the O2 sensor.
Old Feb 20, 2024 | 09:31 AM
JohnLane's Avatar
222 S-65
O2 sensor and vacuum leaks both common.
Even with a fresh O2 sensor it is good practice to check for vacuum leaks.
Old Feb 20, 2024 | 07:34 PM
thomas311's Avatar
I did order a new O2 sensor and some tools related to the job.
I also have a smoke generator which i will use in the next few days. Thank you for your input!
