Electric Issues
door lock switch.
If you do not see anything...
and traced wires on that circuit...
you need to see what amp draw is of actuator when you use it.
Might have some sticky linkage or binding causing overload which means over amp draw which blows fuse....
or youhave the wrong size fuse.
actually found and fixed the issue. the vacuum pump, located in the spare tire well in the trunk, needed to have connector wires resoldering. sometimes they touched and shorted the fuse and other times they just didn't touch and work. freak issue.....
