S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Heater
Old Dec 3, 2004 | 05:18 PM
martian420sel's Avatar
88 MB 420SEL, 84 Mustang 5.0
Unhappy Heater
I would greatly appreciate any help or advice on my 88 420 SEL. Recently it has quit reliably been producing heat. It hasn't quit completely but randomly makes heat or heats during warm up and then stops as soon as I put it in drive. The radiator has just cracked on the top by the overlow hose and I'm in the process of replacing it. Ther is also a ticking sound coming from the right head which worries me. Any insight would be gratly appreciated. Thanks
Old Dec 6, 2004 | 11:09 AM
tgentry's Avatar
560SEL
Intermittant heat could be caused by low coolant level.
Old Dec 6, 2004 | 08:29 PM
Smile
Thanks for the respnse. I appreciate any help. i had kept on eye on the coolant level though and it has always been at the recommended level. Any other ideas? Thank you.
Old Dec 14, 2004 | 09:42 AM
golfboy's Avatar
89 420 SEL and 97 E320
heater problem
Thermostat sticking open?
While the heater is inconvient, I'd worry more about the ticking sound from the head. Could be a lack of oil getting up to the head - either low on oil or the oil pump failing.
I'd take it into a shop for to have it looked at and to get an estimate as soon as you reasonably can.
Old Dec 14, 2004 | 02:30 PM
dtkw's Avatar
1986 560SEL, 97 BMW 740iL
Check themostat and Monovalve.
