how to unlock trunk manualy ?
F248 F1
Hey guys i really need your guys help ! is there anyway i can open the trunk ? when i twist the key to open the driver door, the trunk is suppose to unlock but mine isnt !! and when i go to the back its lock and wont let me open it, i have tried unlocking it with the key in the back but that wont do...it seems like its locked electronicly or something ?? can anyone help me here ? i would really appriciate it ! thanks guys !!
Enrique Gutierrez
Any tips on how to do it pleaseee?
Enrique Gutierrez
1986 560SEL, 97 BMW 740iL
Did you post the same question on another Benz forum with another username?
Okay, use the master key, the one with the red dot. BTW, right now is your key hole on the trunk is in vertical or horizoncal position? If it's vertical, turn it counterclockwise, it should unlock it. If that didn't work, then you probably have some broken part in the locking system.
F248 F1
blahhh its not opening it, well it was working fine--i think i s crewed myself over i took out the locking vaccum that goes in the back trunk..can that b the problem ? if sooo then i need to remove the entire back seat to get into the back and then put it in lol oh boy.
F248 F1
yea i did post it in a diff forum my usernme is f1crazydriver, so you guys saying that i should force air through any lil vaccum hose the ones for the locks ? i believe the cable is yellow and that should do ? but i need to get the part asap before i do it so i wont have to keep struguling correct?
