90 300se W126 ABS brakes acting up
When I was just about coming to a stop during normal city driving the brake pedal would sometimes become softer than normal and then start to pulsate just like they do when the ABS works on slick roads. *Then after that would happen the ABS light would come on and stay on until I shut the car down and restart it. * Also when the light was on I would still have the same pedal feel and pulsating until it was turned off and restarted. * Most of the time the light would go out after being restarted but sometimes it will not. * Also about the same time this started to happen, the ABS light would come on midway during a highway drive. *It does not come on when on the highway anymore but *it is starting to act up more frequently now.* When the car is first started the light it out but the first time I go to stop at 5mph and above the light will go on and the pedal acts funky again.
Any ideas of the cause of this? * If I can not fix it is there a way to disable the antilock system?
Thanks in advance
Dan
Hope that helps
Dan
