S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
CD Battery discharge
Old 03-15-2005, 07:53 PM
Peter Guenther's Avatar
92 500sel/01 320e wag
Well I found it, 92 500 SEL with the Silverstone changer. MY four year old battery was cranking slow, would not hold a charge, I assumed it was on its way out. Mercedes came out and installed a new one. I opened the trunk tonight and heard a whirring noise, the CD player was running, you could not eject the cartrige. The ignition switch was off, the fuse in the font would not disable it, the fuse in the back did but nothing would work. It was remove it and unplug the power wire, and while I was at it I removed the whole thing! The last time the gear fell off and it would not play
Quick Reply: CD Battery discharge
