S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Transmission question
Old Apr 4, 2005 | 03:40 PM
shmelvin's Avatar
none
My 93 600sel clicks in reverse, sort of a ticking noise only when backing up. In all other respects it runs perfectly, no slipping or jerking. I had it serviced a few hundred miles ago and forgot to mention it to the dealer. Usually they are happy to find any problems. has anybody else experienced this and what is the cause and or remedy?
Old Apr 4, 2005 | 04:20 PM
s0vietbenz's Avatar
1995 w140 s500
your car is getting old, you may need to lube the tranny, there is certain liquids you can use.... I forgot the names though. Sorry for the lack of help.
Old Apr 4, 2005 | 07:43 PM
Bernanke's Avatar
yes it happened on my moms 500SEL basically it means the tranny is going to give soon, we ended up just selling the car once it started making all those tranny noises.
Old Apr 20, 2005 | 05:01 PM
Paladin's Avatar
93 600SEL, 89 300TE
I have a 93 600SEL with the same noise in reverse gear but no other problem so far.
Old Apr 21, 2005 | 03:07 AM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
I posted this info here previously, but here it is again. My indy mechanic mentioned casually one day that if I ever heard the tranny on my 140 clicking in reverse, to bring it in immediately. It can mean the difference between a $500 fix and a complete overhaul or replacement.
