S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
500 SEL self leveling?
Old May 8, 2005 | 09:29 AM
alphonso's Avatar
How do I tell if my 93 500 SEL has self leveling?
Old May 25, 2005 | 10:04 AM
alphonso's Avatar
Old May 26, 2005 | 08:48 AM
Peter Guenther's Avatar
92 500sel/01 320e wag
Open hood, look for access (square) panel in cover behind the headlamp access door. There should be a plastic container with a dipstick. Or get under the car there should be hoses coming from the shocks that go to round contailers like a ball, and there should be a valve connected to the rear waybar and axle. All US versions had it standard but I can not guarantee yours. The self leveling pump is part of the power steering pump!
Old May 29, 2005 | 12:08 PM
alphonso's Avatar
Awesome thanks. This one is imported from Japan so it wasn't standard option.
What problems can arise in fitting aftermarket suspension to a vehicle fitted with self leving?
Old May 30, 2005 | 07:48 AM
The first thing would be to see if there is ample adjustment in the self leveling if you decide to lower it. There is an adjustment but I dont know the range. I have been told that the system has a little residual pressure for ride comfort. You should search to see if there are any posts on the subject try
http://www.benzworld.org/
