"Closing Aid System"
Any suggestions ................I took it to a dealer ...........no codes that could correspond with this proble............
Any Ideas ...Guys...
Here's a link to the post, if it works:
http://www.mbnz.org/forums/forums/th...id=13#M1466979
good luck,
Brett
There is some thought out there that the lock mech might get stiff and the pump goes in to the safety failure, that is what you reset when you pull the fuse. In both of my issues a new pump fixed it, one only for a five years, the second who knows
ANOTHER POINT IS THAT MY PUMP IS NOT IN EITHER SIDE OF THE INSIDE LAYER OF THE TRUNK. ON THE LEFT THERE IS THE SUNROOF MOTOR ONLY. ON THE RIGHT THERE ARE ELECTRICAL FUSES/RELAYS AND ALARM RELATED ITEMS. WHERE IS THE VACUUM PUMP FOR THE DOORS?
IS IT UNDER THE REAR SEATS? HAS ANYONE GOT THIS THING IN A PLACE OTHER THAN THE TRUNK?
I REALLY WOULD LIKE TO FIX THIS SILLY PROBLEM. IT IS WORTH NOTING THAT THE DRIVERS DOOR DOES NOT SUCK IN AT ALL AT ANY TIME. FUSE PULLED OR NOT.
MUCH OBLIGED TO YOU ALL
Look at this;
http://www.classic-roadster.de/cgi-b...=&ITEM=M14%2F3
for the pump location. (and please turn caps-lock off:-)
br,
syljua
syljua that web page was most helpful, now I know where to look.
Much appreciated
noticed the doors draw in so slightly beyond locking and then relax as the pressure is relived and vacuum is sent down the line to reset the diaphram. In both my failures repacing the pump cured it, for approximately 5 years and no other items were replaced/repaired other than a trunk lock was replaced when the first pump failed, there was a service bulletin on it. The service bulletin removed the handle retraction from the lock and unlock pump (pse)which has never failed, to the closing assist pump? Go figure!
As you noticed it can work for a while after repowering and why would anyone have an extra. I am on my second, the dealer could find nothing leaking either time. About five years between failures!
