S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Brake indicator
Old Dec 6, 2001 | 02:47 PM
Chard's Avatar
Brake indicator
My brake pad light is flashing on and off. I know my pads are low, but my service rep told me that it's necessary to change the discs as well as the pads. Is this necessary? My car has about 80K miles on it. Also, how much should something like this cost on a 93 S600? Thanks!
Old Dec 23, 2001 | 04:18 AM
RJSL's Avatar
Right Now ... 1999 E55 AMG
I have a 93 500SEL with about 175,000 miles on it and never changed the disc at all. I would recommend you to take off the wheel and take a look at the disc itself. See if it is actually depleating if so you would have to. BUt change the brakes should be ok. If your the type of person who likes to work on car email me and I will tell you how to change the pads yourself, saves you about 200-300 at the dealer. Oh the complete service you mention cost around 600 to 1,000.
Old Dec 23, 2001 | 04:44 AM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
A rule of thumb is to change the discs with every other set of pads (providing you're using OEM pads). Especially if you have a suspicion that your disks are warped (easily felt as vibration during braking). But - YMMV
