SRS + ABS Warning Lights
its usualy the front left ABS/wheel speed sensor that needs replacing or sometimes needs cleaning from break dust crud and deposits.
with mine when the lights came on the speedometer did not work and the power steering was at half power.
If you don't have access to a scanner start off by checking the fuses and cleaning the front speed sensors.
