S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Door Lock Help
Old Jul 8, 2005 | 11:07 PM
djweaponx's Avatar
1995 S500 Sedan
Door Lock Help
OK my S500 is keeping me out. I was locking the drivers side door first because my button on my key stopped locking my car so I was just locking it manually. NOW, the lock on the drivers will not lock at all the key just turns not locking so I have to manually lock the doors from the passengers side.
HELP!
Thanx
DJX
Old Jul 11, 2005 | 08:37 PM
Phoenix's Avatar
97 S500, 04 ML350
when i bought my S420 it had the same problem.
i had to take it to the dealer to fix a few things so i asked them to look into the driver side lock as well, it turned out that their is a simple pin that connects the look / unlock lever with the key lock mechanisem and the pin came out. they did not charge me for the repair but ripped me off $120 to remove the door panel, anyways it fixed my problem, you may have the same thing go wrong.
