S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
door closer
Old Aug 6, 2005 | 08:27 AM
RjRenner's Avatar
1980 450sl,03s500'03sl500
door closer
how cn you tell if my car is equipede with. auto door closers?
Old Aug 6, 2005 | 01:47 PM
BenzKid24's Avatar
a Few Nice cars.
open your door and lightly shut it.
Old Aug 6, 2005 | 04:09 PM
MBHustla858's Avatar
what benz kid says. and ur trunk should have it too. considering ur car is a 500 it should have it, if its not suckin it in ur gonna need the pump in the trunk, i think its close to 12-1500 or so
Old Aug 8, 2005 | 05:52 PM
Peter Guenther's Avatar
92 500sel/01 320e wag
All US 140s had it, pull fuse #9 in trunk if it comes to life it is a bad pump. You will find it over driver rear wheel, way back remove both liners. There were some bad pumps with a bad hose in 95 and MB had a bulletin on it with a replacement hose (in the pump). The pump has a safety if it cant pull in a door in two tries it disables it, this could be from various things. It starts with a signal from the door switch and shuts off with another.
$800 is a better price, $100 if MB checks and replaces
