S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Blower fan
Old Sep 18, 2005 | 10:26 PM
Phoenix's Avatar
97 S500, 04 ML350
Blower fan
does anyone know if the blower fan speed control regulator is the same on a 94 w140 as in a 97 w140.
when the fan is on max it does not blow hard.
I had the same problem with my 94 420. and it was the speed control regulator that i replaced and the problem was fixed.
on the 97 i have a different climent control system, and i dont know if the speed control unit is the same on both models.
if it is i can just order the same part number and change it myself like i did on the other one.
Old Sep 19, 2005 | 01:21 AM
tbilisi79's Avatar
I had this problem when I got the car. A friend of mine that works in a shop hooked me up with a blower and regulator from a 97 S420 that was totaled. I was very happy that day, after all, I was given a $600 part for free.
Since I am not that lucky, I got the fan working but the speed is stuck on LOW all the time. The regulator on this unit was burnt also. But at least I have AC and heat at low Fan speed for now.
I believe 92-99 regulators are the same. Most of them are black, but I have seen some on Ebay that are white in color going for $180-250.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
I only drive the car on the weekends, so this is not a big problem for me. I will get the new regulator at some point.
Old Sep 19, 2005 | 09:20 AM
Rod Spohn's Avatar
2011 E350 Bluetec, 1996 S320 & 2006 E320 CDI Sold to my son & 2017 GMC 2500 Diesel Pick up
Phoenix, I do believe they are the same. If you did this before you know what an easy job it it. I just did mine a few weeks ago and what a joy it is to have full fan speed here in Arizona. Try the place I get my parts www.autohausaz.com they ship free on orders of $50 or more. I paid $170. for the speed control relay Good luck
Rod
'96 S320
'03 GMC Deramax
'05 Suzuki Boulavard
Old Sep 19, 2005 | 09:45 PM
Phoenix's Avatar
97 S500, 04 ML350
thanks guys
i thought it was the same but had to make sure, i guess its a common problem with all of them. and yes it is an easy job to change yourself.
well off i go to order a part
