S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
clunking noise from rear shocks
Old Nov 1, 2005 | 08:25 PM
rambo006jr's Avatar
i had this clunking noise coming the rear of the car, right around the passenger side on the gas tank side. i have replaced the accumulator and the sound is still there. i only hear it going over uneven roads or small bumps at the low speed...i usually can't hear anything from going over large bumps and at high speed...i have read that someone else at another forum had a similar problem and replaced the rear shock absorbers...i don't hear anything from the outside, only when i am inside the car...it makes no sound even if i push up and down on the car...i hope it is the rear shocks as i have already purchased new ones...anybody with my assessment that the rear shocks are the culprit? i have a 98 s500. thanks.
Old Nov 1, 2005 | 10:22 PM
maci911's Avatar
02 s430,98 S320,05 ESV,02 Caravan
how much u paid...........
Old Nov 3, 2005 | 08:28 AM
pcmaher's Avatar
1995 S600 Sedan
rambo, try this link...
http://www.mbnz.org/forums/forums/th...start=1&fid=13
Is this what you were thinking of?
Old Nov 5, 2005 | 06:13 PM
rambo006jr's Avatar
yes it is...i paid 400 for each...just got them put in today but they didn't really solve the problem...i could still hear the clunking noise...any ideas what else could it be? thanks.
Old Nov 13, 2005 | 08:02 PM
rambo006jr's Avatar
so now I have replaced the back shock absorbers, front absorbers are pretty new...the driver side front springs had a crack so I just replaced it this past week...however, the clunking noise is still there...i think it is on the front passenger side...if you shift my weight side to side really hard while sitting in the car you can hear a little of the clunking noise...don't know what to do anymore...I will try the mb dealer when I have more time...any idea from you folks will be greatly appreciated.
Old Nov 13, 2005 | 08:18 PM
Bernanke's Avatar
it get it too, i have new shocks. to me is sounds like bad bushings of somekind, typically control arm bushings. A benz dealership diagnosed the problem of having front control arm bushings and the sound is idential to the one in the rear. so im thinking all 4 corners control arm bushings have gone bad. i could be wrong but thats what i speculate.
