S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1990 300SE Rev. Limiter Problem
Old Dec 25, 2005 | 02:30 PM
szalonynarkotyk's Avatar
Arrow 1990 300SE Rev. Limiter Problem
I don't even know whether or not I know what I'm talking about but I'm pretty sure I have a rev. limiter because whenever I push the pedal to the metal no matter what gear it is in it will hold me a little over 4000 rpms. I have tried shifting down while driving (puting it into gear 2 *its an automatic*) and it just goes vroom and drops to 4000 again. Any help would be greately appreshiated.
Old Jan 23, 2006 | 11:54 PM
MBTEK's Avatar
06 E55, 03FORD P/S,01 E320-4M,99 ML320,O4 E55,05 RUBICON UNLIMITED,
Did You Replace The Fuel Pump Relay? If So You Probably Got The Wrong One. The Wrong One Will Do The Exact Thing You Describe.
