S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Headlight Removal
Old Jan 6, 2006 | 05:13 PM
mcr205's Avatar
Headlight Removal
Hey guys I was wondering if anyone has a step by step removal of the W140 headlights. I remember seeing something on the internet a few months back, but my computer must have eaten the bookmark. I tried searching here and several other forums and have only found info on replacing lenses. Any help is appreciated.
Old Jan 6, 2006 | 08:24 PM
Bernanke's Avatar
I also want to know this. I want to eliminate the yellow capsules in my headlights. Anyone have the write-up of headlight removal?
Old Jan 6, 2006 | 08:43 PM
mcr205's Avatar
OK, well I just finished up removing the passenger headlight and I must say it was a pain in the ***. It's not really difficult you're just gonna need some very small hands to get one of the screws out. First, I popped out the turn signal by pulling a lever. Might I add I found that by accident. Then I took out as many screws as I saw visable. Then I popped off the wiper assembly. Then came the ******* screw which was located behind the neck of the washer fluid reservoir.
Now I'm in bigger trouble. The Euro lights I picked up have different connectors on them and even stranger housings. I'm gonna do some more searching around to see if I can learn more until I make another post on it.
Cheers.
Old Jan 13, 2006 | 08:42 AM
pcmaher's Avatar
1995 S600 Sedan
Write-up to remove headlamps and clean lenses...
http://v12uberalles.com/headlamp_lense_cleaning.htm
