Blower Regulator Replacement - Need Help ! !
Well, maybe.
Here is a photo of the original blower regulator installed.
It is a BOSCH part, the number on it is 9 140 010 099 and says Made in France. The other number (at the bottom) is 90.943.02.225 (not sure what this number is).
Here is a photo of where the blower regulator was removed from. THere is still some residue on the mounting surface that I know needs to be cleaned. The size of the mounting surface is about 1.5" square.
Now, here are two pics of the new part. It is a KAEHLER, Part# 3.701.300, Made in Germany. The Autohaus Arizona Part # is 140 821 83 51. The copper surface is already pretreated with the proper amount of heat transfer agent.
My concern is the size of the mounting surface on the new part. It is the same width as the original, but twice as long (approx 1.5" x 3"). The mounting surface on the blower (1.5" square) is raised from the blower about 1 mm. The holes for the torx screws are in the same location and line up with the blower itself.
Are these two parts interchangable? Will I have any problems with installing the slightly larger mounting plate to the smaller mounting surface?
Any help is greatly appreciated. I would love to have the HVAC working properly in my big black beauty.
BTW, I think the BEHR regulator is the best one, but it is slighly more expensive.
blower motor is located under the plastic cover...under the hood...passenger side...against the firewall. About 10 or so screws to remove.
Could be the resister or motor just like the 1st post here.
I would purchase the cheapest regulator I can find because the transistor quality is the same. You are probably getting a cheaper connectors - but you can re-use your original ones if you want. This is my 5c to this discussion. (do not worry that it is made in France. If German engineering is that good - you would not need to be replacing it - it is their engineering mistake)
