S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Front Shock Replacement
Old Mar 26, 2006 | 10:54 PM
Tone357's Avatar
1997 S-500 Lorinser
I'm about to replace the front shocks on my 97 S500 Coupe. Being a do it yourselfer, (when possible) I "think" I can do this job myself, and save on the dealer charges. Any of you guy's ever done this job? Is there more to it other than bolting on and bolting on?
Old Mar 26, 2006 | 11:06 PM
lesko's Avatar
95' S320
this might help...
http://www.baxnet.com/merc/frontshocks/story.htm
lesko
Old Mar 27, 2006 | 01:16 AM
Tone357's Avatar
1997 S-500 Lorinser
Lesko, you're the man!
Thank you so much! I couldn't received better info than that!
Old Mar 27, 2006 | 01:01 PM
Rod Spohn's Avatar
2011 E350 Bluetec, 1996 S320 & 2006 E320 CDI Sold to my son & 2017 GMC 2500 Diesel Pick up
Lesco
I have been trying to figure out a shimmy at 45-60 mph for a long time tires rebalanced (several times) Front end allignment etc. No one ever even sugjested shocks. They seem fine but I think I'll change them just to see if that does the trick. Thanks
Drive on
Old Apr 24, 2006 | 10:15 AM
Rod Spohn's Avatar
Thumbs up
lesko, Awesome step by step. maybe took 1.5 hours to do the front. DO you have anything like that for the rear? Are they as easy?
I haven't had the chance to get it out on the HWY to see if it fixed/helped the shimmy, but couldn't hurt. I've put over 40k on since buying this car and so I'm sure it was time to change anyway.
Thanks again
Drive on
Old Apr 24, 2006 | 10:36 AM
Hattaresguy's Avatar
1987 300SDL aka the "Money Pit"
The shimmy is probably those fluid filled LCA bushings.
Old Apr 24, 2006 | 12:48 PM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
Front end shimmy can come from many places on these cars;
- Shocks
- Steering Dampener
- LCA bushings
- Ball joints
- Tie Rods
- Wheel out of balance
- Wheel out of true or bent (but balanced)
It is tough to build a 2 1/2 ton car with decent road feel and not pay a price.
At 100k miles, shocks need to be replaced IMHO.
The steering dampener is easliy checked and only requires removal of two bolts. Also relatively cheap to replace.
LCA bushings and ball joints are somewhat more challenging because they require removal of the springs. I would never attempt to remove the springs without a good quality disc-type spring compressor.
Tie rods are usually easy, provided you have a good seperator.
-D
Old Apr 24, 2006 | 01:01 PM
Rod Spohn's Avatar
D, I have replaced or checked everything except the LCA bushing. Is there a way to check this? I still need to find a repair manual, I bought 2 CD versions off ebay ( niether worked ). Did you ever get your new wheels?
Rod
- Shocks
- Steering Dampener
- LCA bushings
- Ball joints
- Tie Rods
Old Apr 26, 2006 | 12:11 AM
lesko's Avatar
95' S320
Thanks again
Drive on
Sorry for not getting back to you sooner but I just made a move to Tampa Fl from Arizona and finaly had a chance to use the computer...Here is a 2nd link that might help you...
http://v12uberalles.com/Rear_Struts.htm
lesko
Old Apr 26, 2006 | 04:36 PM
Rod Spohn's Avatar
Thumbs up To Cool
Thanks for the link.I don't have the struts but the benworld link got me to a picture type discription that was like the one you gave for the front. The rear are almost the same , should be easy. As always you guys are awesome help.
Drive on
