S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Windows up, down, trunk open
Old Aug 21, 2002 | 09:27 PM
Davetruong's Avatar
S500 Coupe
Does anyone know the sequence in pressing the "alarm" control to row the windows up, down or open the trunk? I think I've figured on how to open up the trunk -- press the controller twice when the car is locked. But the rest I'm stuck on... I feel like a true newby to the world of MBZ. Switching over from the Lexus (is that a bad world in this forum?) world to the MBZ world is like going to a different dimension. I'm so glad I did though!
Old Aug 22, 2002 | 01:17 PM
is4b2rd's Avatar
CL500
Closing windows
If memory serves me correct, you can only close the windows and not open them up remotely. To do so, you have to be fairly close to the car and pointing the fob at the little "receiver" on the door handle.
Old Aug 22, 2002 | 02:09 PM
Davetruong's Avatar
S500 Coupe
Thank you for your reply but I think there is a sequence of how many times you press the button on the fob to perform the desired functions. E.g. if you wish to open the trunk you would press the button once till flash green then immediately press it again (or hold it down).
Old Dec 14, 2002 | 06:04 PM
Michael Tubbs's Avatar
S500, benzo
windows up
i too only thought that you could only roll them up not down, I know for fact the trunk is twice to the button, but I haven't read in my book on my S500 anything about being able to use the remote to roll the windows down.
Old Dec 14, 2002 | 06:16 PM
Davetruong's Avatar
S500 Coupe
Windows
Hi Michael,
I thought that was the case too, but when I was fiddling around with the buttons and it went up accidentally. From that time, I've not been able to do it. Wow, it took so long for someone to respond on this message board. But thank you for your response.
Old Dec 15, 2002 | 11:22 PM
utex1988's Avatar
1993 500 SEL
My wife's little sister somehow lowered all of the windows on my 1993 500 SEL while trying to lock the car; I never figured out how she did it and she couldn't re-create what her actions were. All I know is that she managed to lower all of the windows using only the remote......
Old Dec 16, 2002 | 12:26 PM
///MB's Avatar
2024 S580 | 2024 Escalade ESV Sport Plat | 2022 X5M Competition
On our 97 S500... when the car was locked, you press the button twice to open the trunk.
When unlocked and the windows are down, you need to push the button to lock and hold it down... This should close the windows and sunroof etc.
Then the next time you unlock your car, if you closed the windows with the key before this instance, if you hold the button while unlocking, the windows/sunroof should open back up to the previous position.
This is what I recall... we don't have the car anymore, so I can't test it. But, I think it should work.
Old Jan 2, 2003 | 12:49 AM
Davetruong's Avatar
S500 Coupe
///MB
You are right! I tried it out and works. It is important that you close the windows first via the remote.
