S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Oilpressure??
Old Sep 3, 2006 | 04:00 PM
Starscream's Avatar
Oilpressure??
I have a S500 -93.
Whats the normal oilpressure on idle?
Thanks!
Old Sep 11, 2006 | 11:29 AM
Peter Guenther's Avatar
92 500sel/01 320e wag
Almost nothing, depending on your oil viscosity. It should jump right up as the engine speed increases.
Old Sep 11, 2006 | 02:39 PM
Starscream's Avatar
Ok thanks, what kind of oil should i use?
Old Oct 1, 2006 | 08:46 PM
miloking's Avatar
1992 - 500SEL
oil pressure
Mine sits somewhere between 1.5 - 2.0 but it has gone up a bit since i changed the oil.
Iam not sure what oil is the best but my car had all its life castrol GTX 20-50 and i was told not to change to synthetic as its too thin and old engines dont like change like that very much...
Old Oct 12, 2006 | 11:11 AM
The MB dealer put in 5-50 the last time when they switched from normal to synth. My 92 500 SEL only has 90,000 and have had no problems, I tend to have higher oil pressure at idle and cold with synth.
