S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Shaking at High Speeds
Old Sep 27, 2006 | 11:13 AM
MBProS320's Avatar
1984 300 D // 1995 Lexus ES300 // 1998 S320 // 2000 S500 // 2006 Lexus LS430 // 2007 Ford Expedition
Need assistance from my fellow MB enthusiasts. I have a 98 S320 LWB, and for some reason, the car seems to be shaking at high speeds, but not on the lower speeds. I got brand new tires, full alignment, and the shake went down, but its still there. On top of all that, my steering wheel shakes also, even at times that the car is not shaking.
Any suggestions on approaching this situation?
Old Sep 27, 2006 | 05:14 PM
NZ_Benz's Avatar
1993 300SEL/S320
Might be a bent rim.
Old Sep 27, 2006 | 07:57 PM
MB AMG's Avatar
2002 E55 AMG
Try balancing your wheels. I had the same problem as you.
Old Oct 1, 2006 | 08:24 PM
miloking's Avatar
1992 - 500SEL
RE:Shaking at High Speeds
Its a normal issue with w140, i had same issue and after replacing the front sway bar bushings and link rods its gone...
try to start there if you already have new tires and alligment done....
Old Oct 2, 2006 | 09:32 AM
shadowgriffen's Avatar
is a German Tank
This sounds about right to me.
Old Oct 3, 2006 | 12:58 PM
Rod Spohn's Avatar
2011 E350 Bluetec, 1996 S320 & 2006 E320 CDI Sold to my son & 2017 GMC 2500 Diesel Pick up
HAve you replaced the steering stablizer? Could be a cheep fix. I had the same problem.... after several tire balances & 2 front end allignments , it went away when I changed the stablizer. If it started when you put on the new tires you could have a bad one.
Good luck
Old Oct 3, 2006 | 02:53 PM
deuxslow's Avatar
W215
If you're running staggert wheels (wider in the rear than the front) check and make sure they are correctly setup. I noticed that the shop had mounted them wrong. Took me almost a week to realize this. The car was shaking pretty bad.
Old Oct 4, 2006 | 03:33 PM
MBProS320's Avatar
Thumbs up
Not running with staggered wheels, only original 16" rims (old rims cracked in the rain with NJ potholes). Going to have checked (1) sway bars (2) steering stabilizer (3) bent rims. Any other suggestions, please shoot them back on this post.
Old Oct 9, 2006 | 09:27 PM
miloking's Avatar
1992 - 500SEL
wheel shake
I've just found out some interesting info on one of the forums on the w140 wheel shake issue.
Make sure that your wheel nuts are tighten to correct torque and in correct order, apparently that is an issue with the wheels have been tightened with airgun and are overtigh.
Iam not sure about the physics of why that is but something to do with merc stud patern being quite big and bolts being far from centre of wheel...
So if yoou have torque wrech check the correct torque on each bolt and if not get shop to do it....but deffinately no airgun around your wheels.
Old Oct 13, 2006 | 11:31 AM
MBProS320's Avatar
Ill check out the lugnuts. I had a problem about three years ago that was fixed with correct torquing, so let me try again. Will keep you guys updated. Appreciate all the advice.
Old Nov 3, 2009 | 12:45 PM
kenjmoser's Avatar
Folks, I just did the w140 Sway Bar bushings, sway bar links and steering dampner replacement. Unfortunately I had the sway bar off three times as first I got the rear bushings instead of the fronts -- so I replaced the links and ordered the 'new updated bushing' per the MB dealership. I got these took off the bar again only to find out that these parts 14032301085 which the computer said would fit my 93 300SD were for the AMG sway bar and were about 2mm too big. So reordered the originals 1403230985 and finally got them right on the third crawl under the car. I guess the third time was the charm. At least now I new how to do it and on this last try I only had to take off one link plus the two upfront bushing holders -- after cutting off the old it was fairly easy to slide the new bushings on from one side. I anticipate doing this every 3-4 years as it made a big improvement verse the originals that were banging on every road bump at 194K miles. Takes about 45 minutes and only costs about $10. One last note, the bag that the AMG ones came in had been opened so I assume that someone else made the same discovery I did regarding the 'update'.
