No Pump, Trunk Locked. HELP!!!
Hi, i have a 93 S320 and i recently had a water build up under the back seat, which in turn shorted out my Central locking pump when the auto Sparky tried to fix the problem, now my trunk is locked and i have no idea how to get it open!!! tried the key turning pushing turning and poking, but nothing seems to work. is there a way to get it open??? any help would be VERY VERY much appreciated!!!
1 Post
92 500sel/01 320e wag
Pressure to unlock/vacuum to lock
The yellow line on the pump is for lock and unlock, see if you can gently blow on that line 500 mbar is the approximate pressure, so dont just put a tire hose on it, a bycicle pump maybe. I would be carefull and dont break the nipple on the pump.
I guess if it is fried it does not matter, by the way, the replacement is a new style with "t"s, plugs and caps and fittings rather than the plenum.
yellow lock
orange backup assist
black trunk hande
gray orthopedic
clear engine vacuum assist
FKS is for headrestst vacuum if you got them
yellow lock
black trunk hande
gray orthopedic
