S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Power Seat
Old Dec 26, 2006 | 01:11 PM
MBProS320's Avatar
1984 300 D // 1995 Lexus ES300 // 1998 S320 // 2000 S500 // 2006 Lexus LS430 // 2007 Ford Expedition
Question Power Seat
I have a 1998 S320, and think I might need a new power seat control panel. The passenger's side seat is having problems when trying to adjust the seat. The bottom parts work fine, in that they move as they should, but if you try to adjust the back of the seat or the headrest, no movement. At first I suspected something wrong with the seat, but when I try to adjust my seat using the 1, 2, 3 programming switches, everything moves fine.
Any suggestions? What parts I may need?
Old Dec 26, 2006 | 01:52 PM
NZ_Benz's Avatar
1993 300SEL/S320
I replaced one of my seat controls as they are sealed units, spraying some contact cleaner in there did work for me but I had more than one adjustment not working.
Old Jan 2, 2007 | 09:28 PM
JAM's Avatar
JAM
SL600
Had a VERY similar problem in my 97 E320 and all it took was disconnecting the battery for about 10 minutes and then reconnecting. In my E, the memory buttons worked for all movement, the seat back and forth were reversed (pushing forward moved the seat backwards), the back rest and headrest did not work at all. But, again, after the reset everything was fine.
