s320 trans. problem
My wife constantly complains about a hard gas pedal any solutions for this?
Im in So.Cal. so any leeds info on merc. used part houses would be greatly appreciated.
Does your shifter have positions for 2, 3, 4 & D, where 4 & D are left & right of one another? If so, then you have a 5 speed tranny.
If your car is the same as mine (92 300SE), putting the shifter in 2 when starting out causes 1st gear to be used, then it upshifts to 2nd. Also rapid application of the throttle past 1/2 way from a stop will cause the car to downshift to 1st, as does flooring it all the way to activate the kick-down switch under the pedal.
