burlwood gear shifter
.let me know please.
Set the parking brake.
Put the car in N or D - don't have the engine running for this - key does need to move to the ON position and you'll have to step on the brake pedal.
Press down on the shifter and turn to the left (I think) - you'll need to rotate it about 45 degrees - it can then be lifted up.
If you get the shifter handle first, you'll see how it's retained in the mechanism - there's a pin through the shaft that is the retainer. It slides down into a channel and pressing down and turning locks it into place.
There was a lot of dirt, etc in the shifter due to the gate flapper gizmo being AWOL, and that created some amount of corrosion in the mechanism.
I'm sure if I had forced it, I would have broken something. It took a lot of cleaning to get everthing to go back together happily.
