Howdy folks, just purchased a 1992 SE400 with 74,000 miles one it
Long time member of this board (W210) but now I have gone from a 190E to the 400 monster. Picked up the car in Dallas from a private seller, car had all of the records and it is in splendid shape and form.
There are a couple of little things that I might need help with if you guys do not mind.
The windshield wipers seem to "hit" the base of the windshield as they come down every time so they make a fairly loud "thump" noise. I think it is a matter of adjusting them, just wondering if this had happened to anybody here?
The other thing, and I have heard about this, is that the car vibrates a bit once you reach about 50MPH and up. Now the car does need new tires fairly soon, but I have heard that the front suspension,etc..........on these cars is very sensitive........any suggestions? I thought I had heard that there was some sort of damper of something like that to fix the problem??
Anyway, happy to be here and hope to have some good conversations in the future.
Andy
Drive On
Also, the person that i bought the car from, mentioned that the transmission pan needed to be replaced because it was leaking a little bit of transmission fluid.........well, I am not sure that it is the transmission pan that is leaking but more so one of the rubber tubes from the looks of it behind or towards the end of the pan. Any ideas, does this sound like it would be either the pan that needs a new seal or one of the rubber lines that has just cracked? I noticed that it leaked as much as what a car that has the a/c running leaves when it is parked. The only difference is that for some reason it leaks more when the car is going up the drive way then when sitting on a level placed??
I have no problems with the transmission itself, shifting is smooth,etc..........so I might just buy the kid that you can buy that replaces the pan, seal and filter.............along with the hoses that might be cracked? What do you all think?
THank you
Andy
Makes > 1992 Mercedes > 400SE > Steering System > Steering Damper
Part Number Brand / Description / Restrictions List Core Your Price Qty Select
1404630332
Stabilus-Boge
Steering Damper
1 per car. $65.17 $41.95
http://www.autohausaz.com/
As for the Tranny leak..... messy job but rather an easy one. Seal & hose are cheap compaired to the damage that could come from the leak getting worse and hurting the tranny. Why chance it.
They are great cars but can damage your wallet!
As far as the transmission leak, I took a picture to show where it is leaking. It looks like the vaccum modulator, actually the hose or wire that is attached to it is the piece that is cracked and leaking tran. oil................................I took a picture, but the jpe is too big to upload.
