S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Radio replacement
Old May 27, 2007 | 03:16 PM
BudW's Avatar
1993 500SEL
Question Radio replacement
Just got a different radio on Ebay.
http://tinyurl.com/34sl73
So now I will need a code for it, right?
Also, the rear speakers don't work. Dunno why not. But in the boot is a CD unit but no cable to it. It is not installed. Where might I find a cable?
BTW, the reason for replacement is that the tape drive doesn't work. I use it for playing my mp3 or portable cd player so it is necessary. I sure hope the replacement radio's tape drive works.
Thanks for your ideas.
Bud W
1993 500SEL
205,000 miles and going strong
Old May 31, 2007 | 09:40 AM
Peter Guenther's Avatar
92 500sel/01 320e wag
I hope you did not buy it I dont think it is going to work. You are going to have your hands full, 92-94 Mercedes had a two piece radio the front with the controls and cassette, controlling a tuner at the base of the rear wheel thru a large din. If you had the CD, the cable ran thru it and back to the tuner. The previous owner probably disconnected it. The CD is no longer repaired by Becker. The audio is routed to a seven channel amp on top of the drivers side rear wheel, it is prone to failure and usually $500 or so to repair, the radio is still supported by Becker and they suggest you send in both units. The Bose amp drives 11 speakers, four in the back shelf, one in each rear door, two in each front door, and a tweeter behind the rear view mirror and the front to rear is controlled by the fader on the console thru the Bose. The speakers on the dash were for the cellular option. The radio was again changed in 95 to a four channel one piece!
http://www.beckerautosound.com/
http://www.carstereohelp.com/strmercedes.htm
Old May 31, 2007 | 10:23 AM
BudW's Avatar
1993 500SEL
Smile
Hi Peter,
Thank you for your reply.
I received my $45 replacement radio today.
I need the removal tools and also the code.
Who sells the two removal tools?
For my code, my VIN is WDBGA51E7PA122909. Who can use this to tell me my code?
The current radio and its front speakers play nicely
My goal is get a tape player working.
If all else fails, I suppose Ebay gets to collect a second commission when I put it back up for sale so the cost isn't all that risky.
BudW
Old May 31, 2007 | 08:10 PM
Hi
the radio you linked to, came out of a 89 or so according to the E -Bay ad, you will have to try to post the serial number of the radio, there are some who can decode it. The vin for your car wont help unless the radio that is presently in it needs a code. Becker sells the code but it is almost what you paid for the radio. The Becker page shows that it could work in a 93
For your info the radio you have has only two outputs , right and left, and those are sent to the Bose, if the fronts work properly I would think fader maybe. The radio tools can be had from the deale, there are some sold on E-Bay, and some sold at Performance products. I think sorting it all out will take some time
Old May 31, 2007 | 08:31 PM
BudW's Avatar
1993 500SEL
Thanks Peter.
I just opened the box containing my Grand Prix electronic radio. Model No. 754.
Two numbers appear below the model number.
V 6749563
FTZ-Nr.21/560 S
Now something good might be on the side. It is a number scratched into the painted part.
8-5-04 248049 ??
The two ?? represent what might not even be numbers but just scratches. Dunno.
So did I hit the jackpot with the 248049 number?
Thanks again for helping me out.
BudW
Old Jun 1, 2007 | 11:26 AM
BENZITCH's Avatar
1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
I think you have the wrong model radio if it is a be0754. This is a 1 piece unit, used in the 89's. I don't think you have a match. If it doesn't have a mode button on it than, it will not interact with the be1432 2 piece unit. I don't think the be0754 even uses a security code.
Bruce
BENZITCH
As far as a code, I think the dealership parts guy can look it up by the vin number and the or the serial number from the radio. I found the parts guy to be my best source for weird parts and exploded printouts. But you have to give these guys sometime.
Bruce
BENZITCH
Old Jun 1, 2007 | 06:29 PM
http://www.beckerautosound.com/mercedes_year_model.html
754 seems to be a 1986/7 radio code was not used, buyer beware!
Old Jun 2, 2007 | 12:05 AM
BudW's Avatar
1993 500SEL
Angry
Peter,
What can I say? It was advertised on Ebay with these words:
" 1981-1993 MERCEDES BECKER AM/FM CASSETTE AUTO RADIO"
http://cgi.ebay.com/ebaymotors/ws/eB...7555228&rd=1,1
We all know there are honest and not so honest people. Seems I paid $45 to one of the dishonest ones.
So exactly how much does an education cost these days? Is tuition cheaper?
My daughter-in-law is attending medical school at a cost of $35,000 a year I think is what they told us. Of course, school doesn't come with parts guaranteed either.
I now know (education part) that I need a 1432 model. So I am back checking out those on ... you guessed it... Ebay.
Thanks for the chart. It might help in resolving the issue with the seller and Paypal.
BudW.
Old Jun 2, 2007 | 08:53 AM
As you can see by the chart, there are variations in the years and cars the two piece was only around for a while. you could probably make some money on the Silverstone CD changer there were people looking for those a while back. You have to get a code with anything you buy.
I have had my Bose rebuilt, the tuner portion at the same time, and have removed the CD it is in a box somewhere with the phone. It seems sometimes the CD keeps on running, with the ignition off. I purchased a new battery, because I thought it was defective and would not hold a charge
Old Jun 3, 2007 | 12:41 AM
BudW's Avatar
1993 500SEL
Well, as things are working out so far, in the radio department, I have found several 1432s out there for sale. I am the high bidder on one, at $99. The seller wants more but others are offered for, or at least bids are less than my bid of $99.
We'll see in the next few days.
Meanwhile, I discovered why my rear speakers were not working. The fader switch was disconnected and I plugged it back in and all it fine now.
Your help is most certainly appreciated, even if it is to reference me to the work others have provided here. I guess that is how community works best, for others to be recognized for effective help and ideas they bring to a group.
BudW
Old Jun 22, 2007 | 02:32 PM
BeeJay(UK)'s Avatar
S280, 1998
I think I can calculate the codes for Becker Radios, just let me have the serial number
Old Jun 22, 2007 | 03:08 PM
BudW's Avatar
1993 500SEL
Serial No. P 9708388
One chap sent me a program that calculated the code ought to be 3344 but that code didn't work.
So I ran that program to see if it would produce the code for my Becker with the non-working tape drive. It did produce the right code for that radio.
It serial number is 9742697 but it only plays AM/FM and I seem to be missing the cable that connects the CD drive to the second part in the boot so I can't say if it would run that CD unit yet.
Thanks for helping me out.
Maybe it would make sense to buy a radio that plays CDs, DVD music, MP3 and AM/FM?
If the last idea sounds OK, any suggestions about replacement units, such as Alpine or Pioneer or other brands? What about harnesses for the conversion?
Doug
Old Jun 22, 2007 | 03:48 PM
BeeJay(UK)'s Avatar
S280, 1998
Also using a programme someone sent me, but ....
Try 93344
Let me know how you get on, as I am not sure how effective this program is
Old Jun 23, 2007 | 04:29 AM
Untertürkheim's Avatar
Why not just order a radio from ebay.de, there were so many options for radios for your car. The Becker Mexico 2000 1460/1560 models have cd changer control and RDS, way before that was ever offered in the US. That model would work perfectly in your car, far better than any other option.
Old Jun 25, 2007 | 06:44 PM
BudW's Avatar
1993 500SEL
Try 93344
I tried that but the radio only accepts four digits, those being 3344. They didn't cause it to play but left me with "WAIT" for more than an hour. After that, I just put the original radio (that does not play cassettes) back in because we were going on a short drive and I wanted a radio for that drive.
Thanks for the help, or attempted help. I am considering the getting another radio from Ebay in Germany now.
Doug
Old Jun 25, 2007 | 06:46 PM
BudW's Avatar
1993 500SEL
I replied via email too. I am interested but I can't read German as the ebay auction requires there.
Thanks for the reply.
Doug
Old Jun 26, 2007 | 09:32 AM
Doug
I have not replied lately, It should be let the E-Bay buyer be aware. You must be aware by now that you just cant put in any radio on the 140 92 to 94. It is a two piece radio, and not even Becker makes an adapter cable. MB showed an adapter cable in late 94 to use the later radio (95 version)
Old Jun 26, 2007 | 12:06 PM
BENZITCH's Avatar
The cables for the CD player a be0980 unit are hard to find, being sold without the unit.
If any one is interested, I have a complete be1432 system available. Card code the chassis's, speakers and amps. It isn't cheap though.
ALso a few be0980 cd units.
Bruce
BENZITCH
Old Jul 14, 2007 | 12:08 AM
BudW's Avatar
1993 500SEL
This sounds like the battery was changed recently or that it was disconnected.
If you have an owner's manual, it describes how to fix this. Basically, it will tell you to reset the memory of each window by raising each one until fully closed and then holding the switch for an additional two to maybe ten seconds per window. This resets the memory and the windows will work fine thereafter.
Hope this helps and you will find this in the Owner's manual. If you don't have one, one can be downloaded here but I forget where the download is. Maybe at the first page of the forum?
BudW
